Had my car on hunter wheel alignment today and front camber and caster are slightly out as you can see in the pic. Camber and caster are slightly out am I right in thinking worn wishbone bushes would cause that?
Don't think you can adjust caster but camber can be adjusted by undoing the 3 bolts that hold the balljoint onto the wishbone then you can slide the strut in and out as they're elongated holes.
no im not a breakers mate im a vag specialist
i dont use poly bushes as they dont work well on the front wishbone
i would use the standard solid rear bush
