Front fogs not working
Clarke
I've had my car about four months and since having it the front fogs haven't worked. As i got it from a used car dealer they put an MOT on it. Surely if they did not work it would not pass an MOT ive tried the fuse but the rear fogs work so thought they were powered through the same fuse, any help would be great thanks. Aaron
May 13, 2011
549
S/E London/Kent
Front fog lights are not MOT requirement only a drivers side rear is.
Unplug the lights check the pins for corrosion/rust also check tue bulbs while your there.
