Nov 2, 2025
I'm new here and I really need some help. My 2019 2.0L FR with LED lighting is having problems. The headlight level sensor issued intermittent warnings first of all. Soon after the front indicators started failing intermittently with associated warnings. The level sensor warning became permanent. Recently the front indicator failures became permanent. I lubricated level sensor without removal ( as a test ) and the main beam indication light came back but the headlight system still failed to work. Bought sensor replacement for garage to fit tomorrow. Greater concern are indicators... Pulled out hazard switch to get proper part code and fiddled about to no effect. Worried that BCM may be the culprit and it is mega-expensive. I would appreciate any insights, comments or ideas !! Thanks
Thanks for response. Unfortunately only have VCDS older version that relative owns. He said that it will work with the car ( it was his car originally ).
