full beam not working
Lemonsoco
hello does anyone have any ideas why my full beam isnt working it works when you pull the stalk towards you but not when you push it away.
there are no faults for bulb out on the dash coming up.
thanks nick
Aug 28, 2013
523
Lanarkshire
Might be a bit of dirt or dust on the contact, had it a lot on my mk1. Electric contact cleaners the proper method, but I got a tin of air duster from poundland and attacked it with that. Move the stalk through all it's position while you're spraying, see if that helps any. Other than that might be a fuse or relay needs changed somewhere........
Lemonsoco
Ok cheers ill have a try at cleaning It tommorow, is there anyway to test for a faulty stalk?
Lemonsoco
Bollocks lol ill have a look when I get back from work tommorow, I turned the seat belt warning off with vagcom last week do you think I could have changed something causing it not to work?
Lemonsoco
It does when pulled in but not when push out cheers
Lemonsoco
my fog lights aint working either is this linked?
these are the codes im getting
Tuesday,10,September,2013,19:07:13:10074
VCDS Version: Release 10.6.4 (x64)
Address 09: Cent. Elect. Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 086 HW: 5K0 937 086
Component and/or Version: BCM PQ35 M 008 0019
Software Coding: 46180A3C9025B0C04688008095008100050100A8425D81605C80C0008000
Work Shop Code: WSC 12345 123 12345
VCID: F1ED51F79139
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 52611 km
Time Indication: 0
Date: 2109.14.23
Time: 00:23:37
Freeze Frame:
Term 15 On
Voltage: 11.70 V
OFF
ON
OFF
OFF
OFF
00907 - Intervention load Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 174
Mileage: 52611 km
Time Indication: 0
Date: 2109.14.23
Time: 00:23:28
Freeze Frame:
Term 15 On
Voltage: 11.90 V
OFF
ON
OFF
OFF
OFF
02391 - Terminal 30 Reference
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 52611 km
Time Indication: 0
Date: 2109.14.23
Time: 00:21:11
Freeze Frame:
Term 15 On
Voltage: 12.25 V
OFF
ON
OFF
OFF
OFF
