May 4, 2019
Cupra 280 ST, manual gearbox and 100% stock car
Hi, my first post here and sadly, it will be an issue.
I've started to have a gas pedal vibrations or all the pedal box vibrations to be precise. It's doing when car is moving at constant speed, not standing...just having my foot on pedal and I can feel little bit of vibration/tickeling in my foot. It happens in any gear, second to sixth gear mostly.
I tried to find any solution on google, looked at few forums but I've only found VW forum when people described similar issue on Golf R / GTI mk7. They have changed wheel bearing, under the warranty. I have warranty too but local dealer of seat told that they cannot feel anything in pedals... so few days ago I bought both wheel bearings OEM from Seat and get them changed. First ride I was like "oh yes it stopped doing it" but reality is that it didnt dissapear on 100%, maybe 50% in some situations :/ so there is a problem somwhere else too.
Also I am having a clicking noise when releasing clutch pedal in cold weather, during the winter but thats probably not related to this issue.
Did anyone noticed similar issue or solved it?
P.S.: It happened on summer/winter tires and after rebalancing as well.
Nobody has any advice what can cause this issue? I was thinking about reassembling whole pedal box, maybe something is loose. Or some engine bushing...definitely have no idea what should I check first.
