thevanwizard
I have a problem that is baffling me and wonder if any one can shed some light on it i have just swapped the gearbox on the wifes arosa for an identical one im having a few problems when front of car is jacked up about 2 foot goes into gear easily without engine running when its level on the ground it wont go into any gear, second when you press clutch in with engine running goes into gear with no noised but then starts to drive the wheels without letting the clutch out any idea what this could be as been on it for 3 days now and doing my nut in as im not qualified or anything just have basis knoledge and trying to save a bit of money ,
my theory is if its broke have a go you cant brake it any help advice much appriciated
no nothing leaked when i took both out .
i did not change the clutch should i have done as still have the donar vehicle here do you recon its worth a try wondering if i caught the preasure plate refitting it but nothing is grinding
