Gear Ratio comparison help
Dec 25, 2009
1,531
Question i have is which gearbox will given longer gearing with a BAM lump?
ERF ARL 6 2WD Mk4 Golf GT TDI 150, 1.9PD TDI 130
3.238 2.615 3.769 2.087 1.324 0.977 0.975 0.814
ERR 6 2WD 1.8 ltre Golf/Jetta 98-99
3.875 3.100 3.417 2.105 1.481 1.152 1.167 0.970
FZQ 6 2WD 1.8 ltre Golf/Jetta 98-99
3.944 3.087 3.357 2.087 1.469 1.150 1.194 0.975
Hobbiniho
545
9
shetland/ Aberdeen
i have a pdf table that lists gearbox codes and the resulting speeds
At 6500rpm with 195/50/15
ERF will give you a theoretical top speed of 206mph in sixth:whistle:
ERR will give you a theoretical top speed of 145.9mph in sixth :whistle:
FZQ will give you a theoretical top speed of 145.7mph in sixth :whistle:
Hobbiniho
545
9
shetland/ Aberdeen
not entiarly sure you would likely need to work out the percentage difference between the size you are running and 195/50/15's there should be an online site that can tell you this
with 195/50/15's the speeds in different gears are
ERF 35.9 64.9 102.3 138.6 172.0 206.0
ERR 33.1 53.8 76.4 98.3 121.2 145.9
FZQ 33.1 53.3 75.7 96.7 118.9 145.7
FJW 39.4 71.1 112.1 162.9 201.8 241.1
edited to add this is assuming 6500rpm
