Gear / speeds for a TDi?
hakkow
KitCar Wanabee Racer
Jun 5, 2009
162
Netherlands
www.xclusion.nl
Hi everyone!
I'm working on modifying some digital gauges to use in my carPC.
These gauges also include an indicator which gear your in. These gauges get there data from the OBDII interface, and combine the speed and the RPM to calculate which gear your in.
So here's the question;
Does anyone know the gear / speed(s) for a 6K Ibiza TDi?
like this:
I know the 1st gear goes from +/- 1kph to 40kph (1000rpm - 5000 rpm)
2nd gear goes from 15kph (??) to 80 kph (1000 - 5000 rpm)
3rd gear goed from ?? to 120kph ( ... - 5000rpm)
Thats the numbers I know.. does anyone know the rest and care to assist?
Zero
135
You could at least write engine version or even better, a gearbox code.
check here, CTN is for 90HP and CYP is for 110HP (but you can maybe have other gearbox code)
it is in km/h and 195/45 R16 tires
hakkow
Jun 5, 2009
162
Netherlands
www.xclusion.nl
Wow thats amazing!
I didn't know my engine code was relevant for this issue.. But for the record Its a AFN 110Hp. I always thought the 90hp version was the SDI.
Unfortunatly I don't know my gearbox code, but I'll insert the values of the CYP and see where I end up
You really helped me out here! Many Many thanks! :)
Zero
135
yes you can starting to doubt :)
i am pretty sure you have 195/45 R16 on silver multispokes?
hakkow
Jun 5, 2009
162
Netherlands
www.xclusion.nl
You were right indeed! 195/45 :)
The original rims I got with the car were the silver cupra multispokes, but I really liked the white ones :) so I bought those haha!
The numbers you gave are right then! again many thanks!
Whered you get those number anyways?
