Hi guys,
Got a little issue as of today.
When trying to push the gear stick to select reverse i have found it will hardly push down.
Luckily it moves enough to select reverse but something has happened and i dont know what!
Any help??
I assume a bush or something has come off, but really not a clue.
**Solved the issue**
I was correct that the issue was something to do with the bushes/spring.
It was actually the lower bush that had risen out slightly and popped out. The tension of the pressure spring was stopping the bush going back in.
Any help??
