Build sticker, in your service book or on the boot floor underneath the carpet. Looks like this:
It should also be stamped onto the gearbox, on a flat panel next to the gearchange mechanism. On my car it isn't very clear without cleaning the panel off.
You probably have an EGS gearbox.
Hi muttley:)yeah iknow it's a old thread but was doin some diggin on here&found this(as i'm thinking maybe quickshift&need gearbox code 2 check if any differences between 5&6speed)so using your guide looked in my serice book at this sticka thingy i think mines D3AC this sound right 4 150tdi as it says 6M in the code&it's 6 speed?:confused:
Later build sheets don't always have the gearbox code - my current car (2004 Toledo TDI 150 Sport) doesn't.
Gearbox codes are always three letters, so D3AC doesn't sound right at all.
The TDI 150 was always mated with a six-speed 02M box. The three-letter codes identify details such as gear ratios, final drives, oil spec and etc. In terms of the gearchange mechanism it is safe to say that you have an 02M box, as their construction is all the same, only the internal details differ.
The option codes will also tell you a little bit. Looking in the first line you'll find codes beginning with G. My car has
G0K 6-speed manual transmission​
The Phaeton in the photo has
G0Q five-speed automatic transmission for four-wheel drive vehicle​
My old Toledo TDI 110 had
G0C 5-speed manual transmission​
Automatic gearbox transmission
Hi.
I want to know what kind of automatic gearbox transmission i have.
My car : Toledo year 2000, 1.8 engine, AGN.
Mine is broken, i will go to repair it.
Can you help me, because in my country i don´t find (Venezuela)
Thanks a lot
José
Hi,
Where will I find out what my gearbox code is?>
I have a TDi 110 SE (ASV) 2000 W'reg[/QUO
Me too Fisher
I don´t see code on automatic gearbox transmision.
Se below
José
My car : Toledo year 2000, 1.8 engine, AGN.​
I can find three different gearbox codes for automatic gearboxes with the 2000 Toledo and AGN engine, ECK, ELS and EPA. They are all 01MJ 4-speed boxes.
So I guess the answer is 01MJ :)
The three-letter code should be stamped on the gearbox towards the front, parallel to the gearbox/engine joint and above the starter motor. The code and the gearbox serial number should both be in this place e.g. ELS01234
Hi, Muttley
You said " They are all 01MJ 4-speed boxes" but PRND321 is mine, 05 speed.
is similar?
PRND321 is the gear selector sequence
Park, Reverse, Neutral, Drive, limit 3rd, limit 2nd, limit 1st.
This also suggests you have a 4-speed transmission - meaning 4 forward speeds: Reverse isn't counted.
Hi.
Very good explanation, excellent !!!!
José
Other question Muttley:
If a decide to remove that gearbox. How can remove it? I mean it get out below? , i must get out engine? What i should to do? What way?
It is apparently possible to remove the gearbox from underneath by tilting the engine and raising the car. I've never done it. You would need a service manual to be sure, the Haynes manual does include a description of the procedure but very little else
