Gearbox oil seal
ezza24
155
Hemel Hempsted hertfordshire
Hi all has anybody every replaced the os driveshaft gearbox oil seal on a lcr 6 speed box ? I knoticed mine is starting to leak . Is it a big job to do? as the master tech at my place mentioned that he thinks the coupling the driveshaft bolts to is bolted through the centre into the gearbox and , and I just want to make sure there is nothing more to it then that .
Apr 12, 2008
1,197
Not too difficult. You need to drop the drive shaft, and you need a very long 6mm Alan key to get the drive cup off the gearbox. Other than that, its pretty easy.
Apr 12, 2008
1,197
The hole is probably 8mm wide. I think the long snap on ones might just about make it. If not just get a cheapy long Alan key, cut off the bend and put a socket on it. It needs to be like, 3.5 inches?
