aj51 log
I need to know if a 2007 TDi Sport 100 (5 speed) box will be a straight swap with a 2004 FR 130 6 speed box? Are the bell housing and monting points the same??? Has anyone done it??
the front consoles are different between 5 and 6 speed models, i think all gear linkage different too.
What are the front consoles? Linkage points look the same on both box's, it's just the bell housing I'm curious about. Same engine blocks so I don't see why it wouldn't. Just wanting a second opinon before I go ahead with the swap haha.
The box wont be sutible
Irrc the 6 speed flywheel is bigger so the Starter motor won't fit has I will be in a different place to match flywheel if that make sense and gearbox input shaft doesn't fit the clutch iirrc thats why 6 speeders can't use the g60 setup
Gear boxs that will fit are fr cupra and vrs boxs without any modifications
And I think there's a vrs one forsale on brisokda forum if your needing another
