Greetings from Frankfurt/Germany
Nov 28, 2024
I am From German and drive an 2020 Seat Leon KL Xcellence 130 ps
Reactions: Tell and Syphon
Tell
Yes I'm old enough to also remember dads old cars with wooden dash, and on his Morris it had wooden bits on the outside too. Did not know you could still get that effect on a modern car.
On memory lane... now this is the time when cars rotted out :ROFLMAO:. Woodworm must have been an issue and dry rot.
tracktoy
815
662
Yet Morgan still make cars with a wooden sub frame do they not, wonder if damp proofing is on the option list.
CHECK OUT https://www.autoweek.com/car-life/classic-cars/a31118918/are-morgan-cars-still-made-from-wood/
There are dozens of different pieces, all cut by hand and then sanded, massaged and joined into the right shape. The larger piece is then cut to shape and dipped in a treatment solution and hand sanded again.
Morgan’s research shows that the wooden frame makes its cars safer than conventional steel frames on impact tests.
Reactions: Tell
Seastormer
Cupra Leon VZ2 300/CBF1000
Apr 25, 2014
5,405
901
69
Edinburgh (Scotland)
Don't think I would like to be in a car with a wooden frame in a crash, whatever Morgan say. It must be outdated now and sounds like the carts that I ran down the hill back when I was a kid.
mty12345
4,115
680
bristol
My first car was a 1986 Rover 213s with walnut trim in the dash. Took it out and wrapped it in sticky back plastic. Other than bentley and Rolls etc, i didn't realise any manufacturers still used wood either, looks nice though.
Bear
319
297
It was standard in the Xcellence version
When you posted your photos, I bet you didn't expect a load of Brits taking a trip down memory lane with discussions around wood-based dashboards!
