Shar
53
Worcestershire
I'm after some help with how much to lower my Cupra R. I am looking at buying H&R lowering springs, has anyone else fitted them and recommend how much to lower by (I was thinking between 30mm to 40mm)? I'm not bothered about the comfort of the ride, I'm used to hard suspension with my Impreza Type R, I'm more about the looks and handling.
I will be running the car initially with the standard wheels.
Any help / advice will be much appreciated :D
If you want that drop on the Cupra R model then you'll most likely need to go for coilovers, the H&R springs will get you max 20-25mm.
Damian @ DPM Performance
Thanks for your message, I'm defintely only wanting to lower it with springs at the moment. H&R seem to give even ride height, which set of springs would you recommend to lower the car without any further modifications?
My Cupra R is lowered on H&R springs I don't know how much it's lowered it but it looks loads better. Here is a pic, loads more in my readers ride thread. Link in my sig
That's just how I want mine to sit!! Thanks for the pictures!! Looks stunning by the way :D
I'd say the (cant post the URL) will be your best option from what you've said.
Thanks Damien, will 20mm be enough drop?
I think it gives the Cupra R a good stance but if you want much lower then the only option really would be coilovers.
I have just got the h&r suspension kit. Will be fitting it when I get back to the uk do u know what size the boult is on the bottom of the strut is?
Thats no worries :) Thanks for your help!
Will the springs lower my Cupra R by around 30mm? Is it the standard suspension Leon's that are lowered more with these springs?
got a quick question I have a mk2 leon on an 07 plate 2.0 tdi 140 is mine an 1m or a 1p and will the above springs fit my standard shocks?
Sorry to bring this up again but I need advice. I have a 2010 TDI SE, what springs should invest in if I'm just looking for a more sporty look? Thanks in advance.
