dannymanutd
hi basically i have noticed my head lights are hazy would this be on the inside of lights or outside been told this is a common problem with the mk2 leon just wondering if any of you guys have found fix is autoglym headlight restoration any good thanks
Although I haven’t seen this on Leon’s it is fairly common on cars with plastic headlight lenses. I haven’t used the autoglym kit but i did restore the headlights on my passat ( is that a dity word in here ? :p
I used wet n dry and just kept working up the grades and then finished off with rubbing compound.
One tip use plenty of water or you will not get a good finish.
Take your time and you will get a good result.
