cat
Hi, any advice out there ??
I replaced my driver's side headlight bulb with no probs after it had blown.
Trouble is, i found (when i tried to adjust the beam height using the white screw) that the headlight is rocking inside and does not move when the screw is turned.
The motor is working fine (and the other headlight works as it is supposed to.
Question... Have i just lost a simple rod, or fixing that connects the motor to the headlight pivot, or should i look for something else.
Wet and windy last night, and was unable to invest time into looking. Will get out there later tonight though !
