Heater blowing strange fault?
auq
Avoiding Potholes!
Feb 11, 2010
652
Leicestershire
my heater has developed a strange fault, it sounds like all the air is coming from my passenger footwell, but on putting hand the i cant feel anything?, also unless its on recirc the airflow is shite,
any help would be good as im fogging up really bad!!!!!
:cry:
Binksy
Leon Cupra
Nov 27, 2009
89
Norwich
That's where you main fan is to blow the air around your car. It sounds like something has come off or lose take it apart have a look might be an easy fix. Might just need a new fan I'm sure that's where it is and it's easy to get to. Your pollen filter is also there but fitted from the other side under your scuttle panel I would check that to might be soaking wet and that would make your car fog up as you put it ;)
