Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
my heater has developed a strange fault, it sounds like all the air is coming from my passenger footwell, but on putting hand the i cant feel anything?, also unless its on recirc the airflow is shite,
any help would be good as im fogging up really bad!!!!!
That's where you main fan is to blow the air around your car. It sounds like something has come off or lose take it apart have a look might be an easy fix. Might just need a new fan I'm sure that's where it is and it's easy to get to. Your pollen filter is also there but fitted from the other side under your scuttle panel I would check that to might be soaking wet and that would make your car fog up as you put it
