Heater corre
faysal
24
Turkey
hello everyone, sometimes i turn on the heater in my mk4 ibiza 1,4 , and it starts throwing cold air and sometimes its hot air, when the ac is on and the options are on hot it still gives cold air unless i turn off the ac and put it in econ mode.
so i want to check the heater core and possibly replace it, is it a doable job by myself ?
RUM4MO
8,106
1,120
South Scotland
Remember it might just be a temperature flap motor failure, if you scanned that car with a VW Group compliant scan tool it would reveal most issues or fault codes.
One thing to try, demand Hi temperature, wait a few minutes, demand Lo temperature, wait a few minutes, repeat that maybe 10 times in an attempt to clean up the positional feedback track on the temperature flap motor, after doing that you might be able to get warm air out of that system if it was only a flap motor issue, if not nothing lost until you can get that car's systems scanned, and I mean all of them not just an engine scan.
faysal
24
Turkey
the method you mentioned should i try it with ac on or on econ?
faysal
24
Turkey
here is my scan:
Saturday,19,August,2017,18:46:19:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: VSSZZZ6LZ4R051937 License Plate: FL420
Mileage: 136100km-84568mi Repair Order:
Chassis Type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
VIN: VSSZZZ6LZ4R051937 Mileage: 136100km-84568miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Part No: 036 906 034 GM
Component: MARELLI 4MV 5159
Coding: 00071
Shop #: WSC 00203
VCID: 63DCBF5F3B55482A6282911-4B4C
VSSZZZ6LZ4R051937 SEZ7Z0C2179059
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ASR.lbl
Part No: 6Q0 907 379 H
Component: ABS/ASR 5.7 FRONT V30
Coding: 00124
Shop #: WSC 06403
VCID: 42925ADB848F212249F40CD-5140
Address 08: Auto HVAC Labels: None
Part No: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Shop #: WSC 00000 000 00000
VCID: 2558E14775E1F31A4C164F9-5140
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 16524
Shop #: WSC 06402
VCID: 3B6C273FE36550EA0A32591-5124
2 Faults Found:
00906 - Horn (H1)
28-10 - Short to Plus - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 601 E
Component: 0C AIRBAG VW5 0007
Coding: 12355
Shop #: WSC 06441
VCID: 35783107C541869AFC769F9-5140
Address 17: Instruments Labels: 6L0-920-xx0-17.lbl
Part No: 6L0 920 820 F
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 00445
Shop #: WSC 00000
VCID: 2D4819672D11CE5A84A6279-5140
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 63 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 06402
VCID: 70F6C013FAA3E3B2EF00065-5124
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 S
Component: LenkhilfeTRW V260
Coding: 10111
Shop #: WSC 06402
VCID: 3F94532FF77D4CCA261A6D1-5124
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 00 Komfortgerát 0002
Coding: 00259
Shop #: WSC 00203
VCID: 3D682927FD715EDA3406779-4B00
Subsystem 1 - Part No: 6Q1959801C
Component: 00 Tõrsteuer.FS KLO 0001
Subsystem 2 - Part No: 6Q1959802C
Component: 00 Tõrsteuer.BF KLO 0001
Subsystem 3 - Part No: 6Q0959811A
Component: 00 Tõrsteuer.HL KLO 0003
Subsystem 4 - Part No: 6Q0959812A
Component: 00 Tõrsteuer.HR KLO 0003
3 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
00931 - Locking Module for Central Locking; Rear Right (F223)
End-------------------------(Elapsed Time: 03:07)--------------------------
RUM4MO
8,106
1,120
South Scotland
Humm, only the defrosting flap motor showing as faulty, the procedure I suggested will be best tried without the AC (chiller) on.
I've not had a car with defrosting flap motor faulty, so I can't be sure if that would be causing your problem with cabin temperature.
faysal
24
Turkey
hello thank you for the quick reply, i did try it it's the same not hot air
