Hello from GER
dejmos
60
Hey mates !
i think its time to indroduce to you my little yellow rocket and the driver [B)]
my name is daniel, im now nearly 25 years old and come from germany.
the beeza is a 11/00 and a "normal" cupra, so no R !
and sorry for my bad english, its a bit rusty... the last time i was in london is 2 years ago and i still want to get back again :(
mods:
-SFS Performance K04 TIP
-K04 Hybrid
-Wiltec FMIC
-SCAT rods
-8,9:1 compression
-full BAM technic package
-AGN camshafts inlet/outlet (16v feeling, woohoooooo! )
-200 cpsi cat (100cpsi is here)
-70mm selfmade downpipe
-H&R cup-kit (clubsport in work)
-Weitec uprate kit 25mm for the rear struts
-O.Z. Ultraleggera 7x17 (5mm/15mm distances)
-Brembo 305mm in yellow, drilled disks and ferodo DS performance
-LCR lip
-Blueflame exhaust system (wow...)
-Oil Catchtank
-Popoff relocated to the throttle
-removed senondary air-pump
-removed n249
-EGT with digital display at the middleconsole
-Oiltemp digital
-STRI-Racing 3 bar boost pressure indicator
-SPEC Stage 3 clutch
results:
-300ps/489nm (100 octance)
-100-200kmh (60-120mph) in 10,99 seconds @98 octane (racelogic performancebox)
-topspeed 270+ gps
pics:
and the driver:
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Glad to see an overseas member on SCN, welcome. Nice spec you have on the car! Bet she doesn't hang about. Any future plans for her?
dejmos
60
future plans are:
-JBS manifold.... :doh:
-peloquin diff.
-toyo r888 semis
-H&R clubsport coilpack
-all welded cage
-only 2 recaro poles
-oilpressure and lambda indicator :D
oh, i forgot my spec clutch on the modlist :)
