HELP ! alternator belt ! how tight???
sonic_vi
Toledo 20vt
Hi - got a Toledo 20vt sport
Just changed my alternator as the pulley had seized and then sheared off (went from squeeking a bit to dropping off in 2 hours !!! never seen that before)
Anyway replaced the alternator etc and cant get the belt in place
checked and double checked I am routing it right but it seems like the belt is about 1cm too short - what gives?
I've changed belts on astras and vectras before and it was just feed the belt, wind back the tensioner, drop the belt on and let go and the tensioner does the work.
this almost looks like when I let the tensioner go it wouldn't move even if I could get the belt on
Am I missing some trick to getting it back on? Need to get the car back on the road asap so would appreciate the help
Cheers guys
Russ
Ronin225
4,652
22
Worcester
Its not that easy to get on, you need to force it.
Id try and take the tensioner off the pin and see if you can manually hold it further back while you drop the belt over alternator
Ronin225
4,652
22
Worcester
I normally go round the crank pulley and powersteering then up to a/c
This holds it well enough to allow you to get it under the tensioner and then with the tensioner held back I hook it over the alternator
You do have the alternator bolted back into the correct place?
sonic_vi
Toledo 20vt
I dunno. Managed to get it fitted.
Cant see how the alternator could fit any different .
Anyway fitted the belt without the tensioner, then got the tensioner en situ and got one bolt in. Had it locked out with a pin so got a spanner on the tensioner and put pressure on the belt and got bolts 2 & 3 in and nipped everything up. Seems to work ok but thing I need to do a throttle body alignment as its idling rough as hell now. :( must have missed something.
