kofta
hello guys,
i have a problem in my seat leon 2016 when i turned on A/C the Air Recirculation button not working i pressed on it ,, it's closed the gates of the Air to Flipping the air in the cabin not from the wheather outside but when i close this button to take the air from wheather it's not working and still flipping the air in the cabin inside
what can i do to solve this button
sorry for my english :)
hello guys,
Air recycle does not work on mine when I have the air distribution set to the windscreen. Nor does it allow internal air re circulation when I have the demist front screen button pressed on.
Air-conditioning will not run with the fan speed set to off.
I hope that this helps you a bit.
No bro i dont understand what can i do now ?
Is yours the climate control (eg...with the temperatures in digital format, 16.0, 17.5 etc?)
If you have put the fans to the front windscreen, air recirculation will not work. Please try to put the air to 'face and or legs only' and turn the fan speed on, the internal air reciruculation should work.
Yes i put the air on face only .. And when i turn on air recycle it closes the gate of the air and the air in the cabin only but when i turn off the button of air recycle it still close the gates not enter the air of wheather but the button is off .. What is this problem ?
