Hey everyone, your help please.
I have spent this afternoon doing a spark plug and coil pack change on my 2003 MK 1 LCR 1M with the AMK engine.
Got it done and started her up for a quick check before I was planning a quick test drive, how never got as far as the test drive. She started first time and ran fine for about 10-15 seconds then as I got back round to the engine bay from starting her up I could see a grey ish smoke coming up from the coil packs and at the same time she started spluttering and almost cutting out for the time it took me to run around and turn her off again.
All 4 spark plugs were changed and new ones are NGK Iridium IX, model BKR7EIX, all the coil packs are the TFSI ones from Awesome GTI with the adaptors. Previuos coil packs were standard units. All new coil packs are fully down.
When I took out 3 off the 4 old spark plugs out they did have some fresh oil on them. When I took them out they weren't in very tight, and so I didn't over tightern the new ones as I didn't one to crack them, just a bit tighter than the old ones, however never had an issue like this with the old ones.
Only other thing I can say is she has recently been running a bit lumpy at a standstill at idle, with quite a bit of vibration through the wheel espesially. (Dog bone has been polybushed). She has not long been serviced with oil (fachs fully syth from opie oils) she has been running very well other wise boosting strongly and no fault codes.
Any ideas anyone please, as she is now off the road till I can sort this.
Many thanks!!
Many thanks!!
