help, prob with car!
Oct 2, 2006
484
hi just wondered if anybody could shed any light on a prob i have with my car at the mo.my engine management light is on, on the dash, and my traction control light is permanentely on the dash too, and i cant switch the traction control back on with the switch on the dash, it still seems to run ok, but im a tad reluctant to use it, in case i damage anything? what do you all think duff tcs switch?
acidstrato
My Fast says shut up!
Dec 9, 2004
5,942
Newport, South Wales
symptoms would point to your maf sensor being faulty or a a problem with the TCS. but 99% likely its the Maf
drive it to see if there are power issues, if there are, try unplugging the maf sensor to see if its any better.
Oct 2, 2006
484
cheers for the reply, im sure its not the maf as i have had a new one two months ago and it is still boosting and running properly.sounds like a duff tcs switch problem then?
acidstrato
Dec 9, 2004
5,942
i'd be surprised if it is the switch tbh
unfortunately the maf sensor has no actual life span, so just cos its 2 months old, doesn't mean you can rule it out.
its not a guess, its a fact, TCS light and EML together 9/10 means duff maf
if you can vagcom the car, i'd imagine it'll point to that. if not, try disconnecting the battery for 10mins to clear the codes and turn off the lights so you can see if they return
484
help prob with car!
thanks for all your views and comments guys my car had its 50k service today and the seat garage checked the fault codes etc and it was down to a duff maf! the mafs are temperamental things aint they ha! all sorted now though thankfully
