Neil Wilson
hi guys, had my car checked yesterday and the results were as follows
VAG-COM Version: Release 311.2-N
Control Module Part Number: 06A 906 032 HN
Component and/or Version: 1.8L R4/5VT 0001
Software Coding: 11510
Work Shop Code: WSC 24449
Additional Info: VSSZZZ1MZ2R044430 SEZ7Z0A1229582
3 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Control Module Part Number: 1C0 907 379 K
Component and/or Version: ASR FRONT MK60 0103
Software Coding: 0022017
Work Shop Code: WSC 00001
2 Faults Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
012 - Electrical Fault in Circuit - Intermittent
01314 - Engine Control Module
013 - Check DTC Memory
can anyone translate these into laymans terms for me please and recommend what i need to get. i know my maf and abs sensors are knackered so ive already ordered them yesterday but any ideas what other items i need to replace?
Can I recommend you replace what you know is faulty first, then recheck the fault codes? You might find some of the other codes are associated. For example, that bank 1 additive fuel trim might be struggling because the MAF signal is wrong, so it's trying to trim the fuel based on meaningless data.
