Hi,
Was wandering if anyone could help me with these fault codes that I keep getting:
Code:
Address 01: Engine
   Controller: 6K0 906 033 B
   Component: 1,6l/2V SIMOS3  00HSS165
   Coding: 00001
   Shop #: WSC 06402
5 Faults Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
            P0102 - 35-00 - -
17523 - O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
            P1115 - 35-00 -
17923 - Intake Manifold Changeover Valve circuit Short to Ground
            P1515 - 35-00 -
17843 - Secondary Air Pump Relay (J299): Short to Ground
            P1435 - 35-00 - -
17829 - Sec.Air Inj.Valve Circ Short to Ground
            P1421 - 35-00 -
Readiness: 1110 1101
I am going to remove the SAI and put in a resistor so hopefully that will remove the last 2 faults, but was wandering if anyone could point me in the right direction to stop the others coming up?
The car runs fine just the engine light is always on.
Thanks,
