Help with number plate bulbs please lads!
Wolvo-Oleg
304
Wolves
To cut a long story short, reg plate bulbs are giving me grief!
Car came with LEDs, one wasn't working. Replaced with standard, all good.
Decided to fit LEDs again... Bought some cheap eBay ones, these worked then a few days later flickered and stopped. So back to standard again.
Just spent 16 quid on some posh ones, fitted them and neither worked, now replaced with the standards and those aren't working either.
What the hell is going on? :lol:
Wolvo-Oleg
304
Wolves
Haha, yeah not where I go lol.
Really bugging me now, find it odd the originals have now stopped working to even though they aren't blown.
Is there a seperare fuse?
Wolvo-Oleg
304
Wolves
If it helps diagnosing it, I've just used one of those little screwdrivers with the light and can confirm the reg lights aren't getting any power.
Checked a sidelight and it lit up so the thing deffinately works.
Any ideas? Can't use the car tonight if I don't get it sorted :(
Wolvo-Oleg
304
Wolves
Okay, so found the fuse, it was popped. Dropped another 5amp in and the right one worked, put the left bulb in and it blew the fuse.
Please somebody help me lol, why is the left hand reg plate light popping my fuse?
PSX
271
If it's any help at all - not long ago I was blowing (standard, unmodified) passenger-side sidelight bulbs with high regularity, once every couple of months at least. Eventually when I came to change it for the last time, I managed to pull the earth connection completely out of the bulb socket whilst trying to free it from the headlamp unit.
At that point I realised that the earth might have been loose from the start - I managed to pop out the spade connector (if I remember correctly), remade the connection and refitted as well as I could. Since then (many, many months ago) - no more blackened/blown sidelights!
So the above is my reasoning for suspecting a poor earth :) I hope it is just a loose wire and not a dodgy circuitboard driving the LEDs - I'm unsure how the current gets translated for LED setup. Surely the rear bumper is less of a faff to remove than the front!
Good luck..
Alex
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Only ever bought my leds from this seller http://myworld.ebay.co.uk/warden_jp2002/?_trksid=p3286.c0.m198
Look good :)
greck999
SLOW work in progress....
Jul 10, 2009
396
Rugeley, Staffs
The lighting unit can be pulled down without removing the bumper, just get a thin blade or screwdriver down the side of the black plastic surround and it should ease off..
Sent from my HTC Desire S using Tapatalk 2
chrispcupre
767
9
leicestershire
I have bought some led bulbs i am putting them in front sidelights and rear number plate does it affect anything as its lower voltage
Sent from my GT-I8160 using Tapatalk 2
Wolvo-Oleg
304
Wolves
Cheers for the help lads :)
I'm going to have a look tomorrow of its dry! I managed to pop one of the bulb holders into the bumper, so was going to take it off to retrieve it... Didn't notice the two holders were part of a larger panel! (I'm not the most observant of people haha)
Shouldn't be too much bother hopefully! Cheers again :)
Wolvo-Oleg
304
Wolves
Man, what a ballache removing the rear bumper was, so many screws!
After switching bits about and blowing a couple more fuses, it turns out its one of the actual bulb holders at fault, the good one works both sides.
I'm just going to fit a new one and be done with it. Cheers :)
