I have an issue where under Wot and normally in third gear, the car pulls hard up to around 3.5 to 4k revs and then there will be slight hesitation and the revs will drop around 100 rpm for a split second and then pick up again and the car will pull hard again up to redline. It is not clutch slip because the revs never rise, they drop off.
Cupra MK2
Stage 1 Bluefin
GFB DV+
Turbo Back Milltek with sports cat
Replaced cam follower
Fully serviced inc plugs
Everything else standard.
Cupra MK2
Stage 1 Bluefin
GFB DV+
