Hi guys hope some one could help have an issue intake leak its not the pcv or the dv, also codes c.
Nov 19, 2019
Westmidlands
Hi guys hope some one could help have an issue intake leak its not the pcv or the dv, also codes come up
Legojon
I only wanted a remap
5,284
2,714
Well, most of the codes are pending. So normally you wouldn't see those unless you scan. As one of the codes is MAF supply voltage, I'd be inclined to unplug the maf and shove a multimeter in the connector and make sure it is getting the correct voltage.
Nov 19, 2019
Westmidlands
Thanks pal will do that thank you for your reply
