HiD Kits
itsmefishy
327
Nottingham
Been looking on auto bulbs direct at their hid kits, are thay any good? any one fitted one? do you have to drill your headlamps? ive searched the site but can only find info on mk1 leons.......
dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
To fit the kit properly you will have to drill a hole in the headlamp cover to stop moisture getting in the headlamp. I got my kit from HIDS Direct and they have failed twice now, best kit I got was HIDS4U but are abit more expensive :( Other then that, straight forward job :)
Danny.
dannychapman10
K04 Time ;)
Mar 30, 2009
1,268
Grimsby, UK
Yes, as with any HID kit, basically unclip the cover from the back of the headlight and drill the hole to fit the rubber seal in to stop moisture, I went 6 months without my covers on as I never got round to doing it and still worked fine except the ballast died on my current set from HIDS Direct :(
Danny.
wes_keo
wes
Nov 25, 2007
74
Burton Leonard, Harrogate
You drill a hole in the black clip on cover?
yes. the plastic cover you take off to repalce your bulbs, you need to drill a hole through for the wires for the kit to pass through. had to make a 25mm hole for mine. guessing it will be similar if not the same for other kits. i did mine last week. was quick and easy to fit. literally about 15-20mins.
on_the_verge
214
Danny.
Did they replace the ballast / kit? Got mine from HIDS Direct and I am now worried.
AndrewJB
Aug 16, 2007
11,175
485
Maranello
I had a similar problem with my Ibiza
Bought them from Diane Shop , Drilled Holes and fitted them , Looked amazing
2 day later , They broke , Sent back and then sent a new set out , Ive had them a year without any problems , Im about to remove them from my Ibiza and fit them to the Leon (Hope moving them doesnt cause them to go pop)
