Apologies if this question/problem has already been asnswered however, I wasn't able to find anything.
Seat Leon FR TFSI (08)
Recently purchased above car (couple of weeks ago)
When driving and changing gears primarily from 2nd to 3rd to 4th and 5th the engine revs seem to increase rather noticeably. It doesn't happen all the time but enough for it to annoy the hell out of me! Usually occurs when the turbo has kicked in! Is the turbo the problem!?
It sounds like the accelerator is still being pressed however it is not and I'm concious my foot is completely off! Could something be keeping the accelerator active?
I've had the car checked over completely by my mechanic who fully tested the car and resulted in no faults being found other than a minor issue with the drivers side CV joint!? He did also experience the high revs and upon further investigations still no diagnosis.
Is this normal behaviour for this car, is the car losing power and should I be concerned!?
Appreciate all feedback and advice!
Thank you
Thank you
