Jan 5, 2020
Hi all
I have decided to upgrade the mouse fart of a horn on my ibiza 2011 cr sport tdi.
I'm after the horn location ? And is it easy to access and change or is it a bumper off job ?
Thanks All
In front of the car, on the right. Need to take bumper Off. Sometimes you could acces it with removing fog light.. but its not easy..
Verstuurd vanaf mijn SM-G965F met Tapatalk
I think that you will find that your car has a single tone horn, ie a Hi tone, maybe what you want/need to do is to fit the complimentary Lo tone horn, now you should know is that these horns are driven from a controller, and doubling the current draw from controller output might blow that output. So, try to find out which way to achieve what you want before messing anything up, I think that using the power feed to the first or original horn to control a relay for the second horn will work okay as long as you check that there is a quenching diode fitted across the coil of that relay, take a new fused feed from a convenient point to drive the second horn.
Fit some Hella Supa Tones
Gets pedestrians jumping back onto the kerb.
Badger5 Custom Map + TIP,
