how safe are 15mm hub adapters????
Jayt
201
i have been looking at several ways to fit a very expensive set of wheels i foolishly bought just before i changed my car on a whim, to my leon...
the options are hub adapters, or a hub conversion.. my only question is are a set of 15mm pcd adapters from fk racing safe for a daily driver? i know i should go for the 20mm ones but they will cause the wheels to fowl and i dont want that.....cheers for the help guys..
mrcoyote
See no evil...
Jul 26, 2004
2,624
Bit confused to what you mean by hub adapters? Do you mean spacers or something else?
UncleFester
Grumpier by the day!
Apr 30, 2006
4,764
Milton Keynes
www.facebook.com
I'd be guessing the wheels have a slightly different PCD to the car ..... and the adapters needed are 15mm thick.
I run 16mm rear spacers and 10mm fronts - i would not want to fit wider than that on the front using the current offset ( around 35mm i think) as the wheels are on the very edge of being too far out of the arch.
Jayt
201
well uncle, do you have any trouble with the wheels fowling in the arches,
as far as the adapters are concerened basically it is a pcd adapter, the wheels are a 5x112 and the hubs are 5 x 100, so what you do is bolt this aluminium ring in and then bolt the wheels to it. but i have seen it said they are too thin to be safe on a car used everyday and i should go for a set 20mm thick as they are mucho stronger........ obviously i dont want a wheel flyiong off and going faster than my car can......
Jayt
201
funny thats about 25 quid cheaper than europeancar parts and other places normally sell for 105, but if anyone on her speaks german and has five minutes to spare i could order them for 80 euro off the fk automotive website.
olaf
Dodo Lover!!
Aug 19, 2006
1,081
29
Ipswich
They will be expensive as they are conversion spacers not hubcentrics.
Think most H&R conversion spacers are over £100 a pair.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
conversion spacers dont usually come in les than 25mm thickness.... else how do they loose the bolt head and allow sufficient thickness in the material, strength wise?
Jayt
201
think i might buy them and if one fall off then i know its a bad job wont i, the 15mm fk ones i think are tuv approved so i doubt they can be that bad, and its not like there going on a lambo or something fast only a dirty diesel,.....
i know that they use special bolts to connect these on.. but it was the lack of material that concerened me as well.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
that really assumes that TUV approval is little more than ISO doesn't it
Does it mean that the spacers have had material failure analysis performed? or just that the company that makes them has a quality manual?
or somewhere in between
herb2578
now a cupra owner
Jul 14, 2007
145
west mids
are the wheels 4 or 5 stud????
