Im abit confused, if i remove strut bolt wont it come flying towards my face due to the spring pressure.
Just to add, will my height adjsutment get effected when i replaced the mounts over?
Cool, so is this right way to remove it: remove the 3 bolts and remove bolts from lower disconnecting it from wheel hub.
Compress the springs and remove bolt at the top mount to seprate it from coilover arm.
How do you remove plastic cover on top mount? does it only pop off from car coilover is reved from the car?
I did try with flat screw driver but wasnt budging, will give it ago with some G pliers.
How easy would bolt holding topmount be, i know some garage use a impact gun, as with a wratchet would twist the whole shock asborber piston with it (may be different with coilovers).
You will need an offset ring spanner to get at the nut as you also have to hold the strut still with an allen key otherwise it will just spin...you will see what i mean when you come to doing it...
Oh and just to clear things up about spring clamps etc...have a look.
http://www.youtube.com/watch?v=CYFOI_UsVxI&feature=related
