How to turn off cornering fogs
Catzeye83
49
Newcastle upon Tyne
Hi everyone, as the title suggests how do I turn off the cornering fogs on my 16 plate 5dr Ibiza fr 1.2 TSI? Been right through the menus and crnt find the option! Also I've noticed when I select reverse gear it puts the front fogs on also!! Anyway to turn those off Also? Thanks in advance for any help
SRGTD
2,683
1,532
There isn’t an option to turn them off in the menus because I’m assuming Seat didn’t intend them to be deactivated. The front fog lights on my VW work in exactly the same way and I can’t say it’s ever bothered me - in fact I actually find the cornering light function quite useful.
if you do want to deactivate them, then they can probably be coded out with VCDS, OBD11 or similar, although before getting this done it might be worth checking to see if front cornering lights - if fitted - are checked during an MOT test (I don’t think they are, but worth checking first).
Reactions: Catzeye83
Catzeye83
49
Newcastle upon Tyne
Cheers for this, 1st car I've had with cornering fogs, was thinking I may have missed something in the menus! Your right they nit that bothersome, cheers again for the reply👍🏻
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
That did bother me, so much I bought myself Carrista, plugged into the port to turn the cornering fogs off (I had bi-Xenons, so those fogs just look, out of place). However I did enable some cool features such as startup needle sweep, lock with a chirp, and in the menus there were more options like 'turn on/off DRLS' and 'turn off DRLs when handbrake applied'. I did also enable mirror fold on lock, but that rarely worked, or they worked when I didn't want it to.
Catzeye83
49
Newcastle upon Tyne
Ah yeah my Octavia MK2 vrs had those options to select from the options, may I ask what is carrista?
Catzeye83
49
Newcastle upon Tyne
Cheers for response, do you need to buy a cable for carrista? Also are the options easy to activate deactivate one I have the software and cable, cheers
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Just plug into obd port and connect to phones Bluetooth. Need to download app though. If I recall correctly there's like a trial period where you do all the stuff for 1 week or something.
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Also the newer cars after I had the Ibiza all no longer had cornering function, heck they didn't even have fog lights anymore! That been said they had full LED headlights, and they were bright enough. Likewise when I did have the fog lights, in 4 years I've only really had to turn them on once or twice for 10 mins or so in heavy fog and heavy snow (I know, it's not foggy, but it did let me see near the ground!). Not sure why the my Ibiza needed cornering fogs, when it has AFS (cornering) Bi-Xenons.
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Cheers what do I plug into the port, like I said do I have to buy the cable seperate? Cheers
Yes you plug that oversized looking USB stick into the OBD port, and connect to your phone via bluetooth. Prior you need to download the carrista app, which I think has a week long free trial period. Or you can see which functions it has, and once you seen them, start your trial and make the changes. There are no wires required. If i recall corectly, just below the light switch, there is a covering, if you gently open that, you will see the OBD port there. I'm not sure if you are based in London or how urgently (or annoyed you are with the fogs) you want to try carrista, but i do have carrista that i used once and it is not compatible with my current or future car. Rather than collecting dust, it could go to a new home..
Catzeye83
49
Newcastle upon Tyne
Cheers, sorry for sounding bit stupid, wsnt sire that big block thing was what you plugged in haha, I live in the northeast of England so quite some way away😬 how much would you be looking for the adapter and would you consider posting? Cheers
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Yea I can post it, direct msg you?
KXL
KXL
Dec 15, 2016
1,579
195
London, UK
Hiya @Catzeye83, just sent you a PM now that I'm back in the country.
