HPFP upgrade - what about camshaft/follower?
ferooo
Hi,
I'm going to upgrade high pressure fuel pump to Autotech one. Question is what else is needed?
I red somewhere (and also on HPFP package) that is required change also camshaft (if the old one has part number: 06F109101A) to version B.
I checked ETKA and found that BWJ engine has 06F109101G camshaft.. :confused:
And if the version B is installed, than is necessary to check/change only cam follower (part number: 06D109309C).
So what is right? What I have to change? Part numbers are right?
robdf2
Yellow is the best
Feb 21, 2006
3,605
location , location
The cam shaft issue was more aimed at early gti's I'm sure no Leon's were affected by this
What year is your Leon ?
You should be checking your cam flower at least once a year for signs of wear or damage.
If you replace your hpfp then you will need to change your cam follower at the same time and at least once a year from your instal time.
ferooo
my Cupra is 2007. I already ordered cam follower. I'm gonna change HPFP in 1-2months, so at that time I also change follower, just for sure:)
It looks, that Cupra has cam shaft already G version (06F109101G), so I purchased spare CAM follower (06D109309C), it only cost 25-30euro. Hope it will be the right one :)
