Mar 6, 2024
Hello guys!
I'm proud owner Seat Leon Cupra 1P with tuned BWJ under hood. After rebuilt of engine (new pistons, forged rods, new rods bearing, renewed head etc.) engine started to misfire on cyl. 3 (about 14 missfires per minute) and cyl. 4 (about 2 misfires per minute). It's only misfiring on idle, also turning on AC is making amount of misfires lower (about 5 misfires per minute on cylinder 3, and no misfires on cylinder 4). There's no single misfire when there's load on the engine. We decided to change coils and spark plugs, but nothing changed. Then I bought brand new injector and replaced it on cylinder 3 to check if there will be no more misfires, unfortunately they're still there. We have also checked the compression, there's 180 psi on every cylinder. After 3k kilometers I realized that I can smell petrol in the oil, I think it's somehow connected with those misfires. There's no carbon buildup - it was cleaned during rebuild. I'm also changing cam follower every 10kkm and there's brand new VIS motorsport internals in HPFP.
There's no single error code in ECU, but misfires are clearly visible on VCDS counter.
Thanks in advance for your support!
Hello guys!
Smell of fuel in oil solved. Still misfiring on idle.
Wiring is fine, sparkplugs gapped to 7mm. I've also changed the PCV, but still same behaviour. I'm also considering to change N80 valve.
Hi there what caused the oil to smell like fuel and did you manage to solve the misfire issue?
Hello,
smell of fuel was caused probably by leaky injector - I've changed HPFP and injectors. Unfortunately car is still misfiring on idle, in meanwhile I've changed coils pack - but no effect.
You can check injectors easily on VCDS, if after shutdown of engine rail pressure is decreasing, probably you have leaky injector.
