spy
16
i checked my car with vag cable vcds from ross tech several times and always i have error
01596 - motor for outside/recirculated Air Flap (V154)
30-10 - open or short to plus - intermitted
29-10 - short to ground - Intermitted
That is the message from the vcds
And i bring the motor out side the car and i try it by small 12v battery and it work and i searched in ross tech site about that error but i found nothing so plz help me what can i do :help: :banghead: :banghead:
And so what is the solution
And i need to know what is the reason
:banghead:
:banghead:
So, you have tested this flap motor assembly using a 12V source and it moves, in the car it will probably get supplied with a lot less than 12V and its movement reported back via the positional feedback signal.
What to do next, well you could replace that flap motor - but remember to perform basic settings using VCDS, maybe run that test on that motor while it is in position.
No i try the air flap motor inside the car also and it work
the air flap works when i push the recirculation button in hvac unit but some time while i close the air circle and the air flap button is on and it's light is on suddenly it's stop and open the circle and i need to push the button many times to close the circle again all of that and the aircondition is running without any problems so i need to know where is the proplem and every time i check by vag cable i have the error 01596
