Cupra999
13
Hello All,
I read that Bilstein B6 can be good fitt on some car and can be bad on others due to incorrect valving.
someone knows if Bilstein B6 will be more comfortable on Ibiza cupra 2002 than the OEM struts with the OEM sport springs?
What about Koni sport yellow, will it provide more comfortable ride?
B6 yellow and koni ste is more stiffer the car in a good way with stock spring I go to koni active is the best for that u asking
I don't think that there is Koni active for this model,
What should last longer the B6 or Koni yellow?
They have Koni 8750 1009 which is STR.T which is Koni Orange, the quality of them much lower than the B6 or the Koni sport yellow, not sure if it worth to install them for that.
Koni Active is Red
You are right,
2002 is 6k2, on some websites it's 6k1, so when buying something on the web it can be 6k1 or 6k2 but
2002 cupra is only with 1.8T and the 6L cupra introduced in 2004
There is no problem to identify the car, the discussion was for general information.
In Autodoc->Seat-> Seat Ibiza II (6k1)1993-2002-> 1.8T 20V Cupra 156 PS (2000-2002)
