After trying to post on FB pages for help and getting nowhere I thought I would try this seen as forums used to be excellent for this sort of thing!
AC hasn’t worked in missus Ibiza for a while, has worked when it was bought but about 12 month later it stopped.
Attempted a halfords regas which they couldn’t manage and it just leaked straight out from somewhere.
Went to a garage to have leak detection done, they said it was the “compressor behind the dash....” (think he got his terminology mixed up) and it would be a dash it job. I wasn’t convinced and thought I was getting mugged off
Seen as my own leon had an AC fault I bought a set of AC gauges and fired some compressed air into the Ibiza whilst I was at it to try and find the fault myself.
So with the system at 50psi I started spraying soapy water around the bay with AC off, nothing to be seen. I then started the engine and AC on and started getting bubbles from the plate where the two AC lines go through the bulkhead into the evaporator I assume. I was getting like a howl/ whistle from the AC, and the compressor definitely kicks in (see rpm drop and hear it engage)
Anyone seen this? Is it likely to just be an R134 gasket on the two lines or is it a common fault for the evaporator to just fail for like no reason.
I do have videos but figuring out how to host stuff nowadays is difficult.....photobucket doesn’t do videos anymore
