benh999
how many litres water does the cooling system on the ibiza approximately hold. The bottom hose to the rad had a split so we've replaced and drained down the system to refill with fresh water/coolant.??? So far we can only get 2 litres of water/coolant mixture into her. I am assuming there is an air block somewhere. How can I over come this?
Is there an air bleed valve anywhere that needs to be opened when filling her up or is it just a case of filling up through the white header tank???
cheers
Ben
cheers
Ben
