Jan 7, 2026
Hi fellow Ibiza fans,
I have an Ibiza FR 66 plate and once again the water jet fuse has blown. Does anybody know which fuse box and the fuse location number inside that box so I can replace?
Thank-you in advance
Gareth
Gareth
It's number 9 in interior fuse box (SC), 10A.
If it is blown, your rear wiper shouldn't be working either.
Reactions: GarethO
If it keeps blowing fuses, it suggests that the pump is faulty... if it's partially seized then it may be pulling more current when operated than the fuse is rated for.
Reactions: GarethO
Maybe even no or not enough winter screen wash in the washer fluid - and it is slushing or freezing.
Anyone know why there is so much "effective down to -5C" windscreen washer fluid on sale this year - that might be good enough for some areas of UK if you are lucky, but certainly not good enough for all of UK?
