Ibiza Mk5 Rear reflector replacement??
everson38
470
35
walsall
Hey guys
I have a 62 plate Seat ibiza 1.2 SC TSI (6j i believe). Some git me at the back, does anyone know if the driver side reflectors on rear bumper are pop out job or a bumper off job? If its a bumper job off. If anyone can tell me any youtube links of a similar vw cars that have the.same process that would be amazing
Thank you
Sent from my SM-G935F using Tapatalk
SEAT Rule
188
62
Hey guys
Thank you
Hello there,
you don't have to remove rear bumper to replace rear reflector/s, I believe the reflector will prise off gently with a small flat ended screw driver, the new one should simply clip back on.
The reflector has at least one holding clip that's moulded to it, plus will have a guide lip/tongue to aid fitment.
From 2008 to early 2010 part number 6L6 945 105A (for standard & FR models)
Cupra model is 6L5 945 105A
Left side rear bumber reflectors.
From 2008 to early 2010 part number 6L6 945 106A (for standard & FR models)
Cupra model is 6L5 945 106A
Right side rear bumber reflector.
6J3 = 3 door model
6J4 = 5 door model
From mid 2010 to 2012 part numbers
6J3 945 105B & 6J3 945 105C
Left side rear bumber reflector.
6J3 945 106B & 6J3 945 106C
From mid 2010 onwards up to 2017 new part number added for 4 door models 6J4 945 105A & 6J4 945 105B &
6J4 945 105C (left side rear bumper reflector)
Part number 6J4 945 106A &
6J4 945 106B & 6J4 945 106C
(right side rear bumper reflector)
From mid 2012 to 2014 part number
6J3 945 105E
6J3 945 106E
From 2014 part number
6J3 945 105G
6J3 945 106G
Hope this helps
Si
Reactions: everson38
everson38
470
35
walsall
Hello there,
6J3 = 3 door model
6J4 = 5 door model
6J3 945 105E
6J3 945 106E
6J3 945 105G
6J3 945 106G
Hope this helps
Si
Thank yoy for this. You were correct you can clip ot out. But you can also release part of the wheel arch liner and two bottom screws under bumper if you want to access it from inside the bumper. Massive thanks for the part numbers great help thanks.
