In Car Heater problem - please help!!
j4ck50n
Hi people
Was wondering if someone could help me please.
Got a MkII Ibiza Cupra Sport Gti 8v and am having some problems with the in car heaters.
The heaters, which have always worked spot on till now are playing up
They are cold for much longer, then tend to heat up when the revs go up with the engine under load. Once backing off again and going with the flow of traffic the air goes cooler again, although not totally cold.
Could it be the thermostat?
Any help would be greatly appreciated!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
coolant will flow to the heater matrix if the thermostat is stuck - I know this as it's how I've got home! turn the heaters onto max....
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Following on from this, does anyone know if its easy or difficult to change the light bulb behind the switches for the heating system??
5 mins more or less
the front facia clips off - usually from underneath - GENTLY up each side and watch for the clear bits going everywhere
you'll see 3 dials with 4 screws (1 in each corner) undo em - dont lose the clips if they fall
work the heater panel out through the gap sideways - it will go eventually
on the back theres a white shroud with a single bulb/holder - bingo
http://groups.msn.com/FLAPPERSPLANET/projectxbox.msnw?action=ShowPhoto&PhotoID=1051
might help
