taylor1563
hi all,
when i bought my cupra it was fited with a k and n, a cat back exhaust and had been remapped by previous owner and is currently runnng/ holding 10psi which i thought was a bit low for a claimed 200bhp!
ive since added forge diverter valve and ths fmic i also have a forge tip on order!
looking at getting it remapped to the new mods i see custom code are doing 30% off at the moment anyone use there maps? boost pressure when mapped? bhp?
any other companys good and also should i get a sports cat aswell? much difference?
bit of an essay i know but i like to get as much info as possible before i make a decision and part with my £££ many thanks in advance guys:)
i thought they ran around 10psi on the stock map? do you know who remapped the car previously. i've heard good things about the custom code maps very smooth aparently! not sure on the psi. Should be running around 200 i should think, if not a bit more with your current mods!
there is a certificate in the history folder i got with the car saying it was remapped to 198 bhp by www.rapidremap.com
when i first got it it was running/ holding about 11 or 12psi which has dropped to 10 since fitting the intercooler im guessing due to the pressure drop you get across the bigger cooler and pipework!
im very tempted with the custom code map due to the price they are doing it for at the moment as i want to get the best performance from my modifications!
looks like i will benefit a lot and feel a difference from getting it mapped again then?
