Injector Pump?
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
P1256 - 35-10 - - - Intermittent
17672 - Pump-Jet Valve: Cylinder 2 (N241): Regulation Range Exceeded
P1264 - 35-10 - - - Intermittent
17669 - Pump-Jet Valve: Cylinder 1 (N240): Regulation Range Exceeded
P1261 - 35-10 - - - Intermittent
17675 - Pump-Jet Valve: Cylinder 3 (N242): Regulation Range Exceeded
P1267 - 35-00 - -
18072 - Pump-Jet Control: Malfunction in Circuit
P1664 - 35-10 - - - Intermittent
Basically this is a friends Bora... turns, but won't start or even catch I think it's a PD130 - any pics of where the Pump is? I cleared these faults, then turned over & got these faults
3 Faults Found:
18075 - Valve for Pump-Jet: Cylinder 2 (N241): Electrical Malfunction
P1667 - 35-00 - -
18076 - Valve for Pump-Jet: Cylinder 3 (N242): Electrical Malfunction
P1668 - 35-00 - -
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
those valves , n240 241 242 243 , are the PD units units mark , starting left to right as u look into the engine bay , that sounds like an expensive fix , could be worth to check the engine multiplug isnt loose , its located on the right hand side of the engine , near the fuel temp sensor ,
EDIT the tandem pump is located on the right hand side also , on the end of the camshaft
m0rk
sarcasm comes free
27,785
33
Clanfield, UK
Yup - that was it
Now it runs **** & 'sounds like heavy rain' when on boost
and smokes a lot
that sounds to me like rain = bearings, smoke = not much air
basstard
Dropping Cogs is Useless
Aug 24, 2002
2,746
Roma, Italia
when I fuct a bearing on mine is was 'pinging' even at idle,,,
test the turbo 'area' with vagcom and see what it says for the smoke matter,,, could be also bad injection tho,,,
muddyboots
Still hanging around
Oct 16, 2002
5,739
To get faults on several different injectors sounds like a wiring issue to me ?
IIRC the wiring to the injectors runs inside the head, bathed in oil....nice.
prc
Sooty Meister
1st clean the contacts on wiring harness (left hand side of motor). If that doesn't work then swap the internal harness (runs under cam cover and is easily accessible). Not hard to do and also not expensive (around 70 euros).
The cable comes with all conections/connectors so pretty easy to do.
