Depends if you're going Stage 3 in the future?
If you're going stage 3 then for me its either the IE or Wagnar. They're not cheap but I'd argue they're the very best coolers money can buy and the IE in testing cools the best (relative overall to the pressure drop).
BUT
If you're only going Stage 2 then I'd go DO88. The price for its performance is outstanding, however that's not the reason I recommend it (its what I got).
The boost drop across the core is significantly less than any other cooler on the market, yet its temperature delta is still better than a lot of the other coolers (except say Wagnar). Why is this important? Well its putting less stress on your standard turbo, it doesn't have to work as hard to produce the same level of boost going into the engine:
Graph Sources
You can never guarantee things won't break, but Stage 2 is pushing your standard turbo to its limit.
Hence why I say if you're going stage 3, the turbos will have a lot more headroom, so reducing the temperature is more important.
All the above is just my opinion mind and some of it may not be based on 100% hard fact, just my own general education and knowledge, so if others have evidence to say otherwise then so be it.
However, its worth checking this site out, for him its a toss up between the DO88 intercooler and IE, but being based in the states, for him the DO88 is significantly more expensive to import to the US, so the IE is significantly cheaper. From memory when I got mine, importing an IE cooler from the states to the UK would of been just over double what the DO88 cost me.
Mk7 GTI and Golf R Intercooler options are compared by looking at single gear pulls and the resulting temperature rise over ambient temperature.
mygolfmk7.com
do88 intercooler for the Mk7 GTI is tested on a flow bench for pressure drop performance and airflow then compared to other stock location intercoolers.
mygolfmk7.com
do88 intercooler for the VW Mk7 GTI is subject of a bench cooling test and compared with other aftermarket intercoolers for the Mk7 GTI.
mygolfmk7.com
