WALK + MAP Tweak
11 Nov 2010
In with Monster Motorsport today, still can't fault the staff and dedication to go the extra mile to
help you out.
After having the Autotech HPFP internals fitted last week and not getting time to set it up (tweak on Dyno) came back today to have this done + for good measure has one of my handling mods installed;
The Whiteline Anti-lift Kit (WALK). I also chose to have the front inner front wishbome bushes upgrade to Powerflex ones too as this is recommeded if fitting the WALK kit;
WALK
As for how does this feel to drive afterwards these are my early observations albeit pissing down with rain so difficult to give a good
review for nwo;
- It felt to me the steering had firmed up a bit and now gives a more positive feedback
- Also I would say feels better in the corners too
- When pushing it you can feel it doing what it is designed to do, resist the lift!
- Very wet so unable to confirm if giving better traction
- I have not felt any additional vibration or negative feel to the car
Points to note it will need re-alignemnt setting done again but I plan to add ARBs and Mounts before getting this reset
Overall I believe a good investment
Dyno run and revo tweak to take account of new Autotech HPFP.
Dyno a stage 1 with ITG and Autotech HPFP
Previously on the same dyno my car just squeezed a few decimals over the 300 bhp mark.
After some tweaking and about 8 or some runs it only made 305 which was less than I expected albeit the graphs were nice and smooth. Car left to cool as suffering heatsoak and a bite to eat in order!
Monsters own
Cupra made 322bhp with the same mods so Neil (from Monster) looked at their graph and settings, did a bit of tinkering and the graphs where now consistently running above 310bhp and best run just shy of 315bhp which was more in the region of what I had anticipated. I would have hated to have paid all that money for 4 bhp
May car has now been on the rollers 3 times at Monster and if you look back through my build thread will see it has always been a little short of the expected numbers (run 225bhp as std and 273 with stage 1, 300 with stage 1 and ITG).
Having had a new CAM follower installed, new HPFP internals and the Rev D DV I was hoping this may have rectified any past potential shortfall in numbers compared to Monsters
Cupra.
Don't get me wrong 7bhp difference is an acceptable range in my opinion, it's nice to have a
guide to compare against and I do not feel anything is wrong with my car.
However, for peace of mind Neil took my car on a good 1/2 hour run on the road and did some logging. There is a little concern on the air flow readings from the report as they are outside the range revo would expect to see.
Neil has sent these to REVO to see if anything to be concerned about and mentioned possibility of a faulty MAF sensor? (This could result in some loss)
Unfortunately I do not have the reports but will report back in a few days the findings. I've also forgotten what Revo setting it now has!!
Many thanks again to all the staff at Monster Motorsport in Loughborough. They really do go the extra mile to make happy customers and show their true enthusiasm for what they do and what you want for your car
Next upgrade(s) on the list
I have these in the garage (THS Performance FR3 Engine Mount set). These are side Engine, gearbox and torque mounts)
I also plan to add either Whiteline or Eibach front and rear ARBs before getting the geometry reset
