ipod adaptor
waynejacobs
wayneo
Aug 10, 2006
107
cambridge
good evening guys
a couple of questions firstly ive got the standard arura single cd head unit in my lcr wanna use my iphone to play my tunes do i have any options apart from changing the head unit?secondly i wanna fit a center armrest does anyone know the part numbers i need when i order it from vw?
many thanks guys........
Mar 3, 2009
823
Hinckley
CTASTIPOD001 if you have cd changer
CTASTIPOD003 if you dont have cd changer
Both allow control on the stereo
For the iphone to charge you need a passport to convert the voltage.
Mar 3, 2009
823
Hinckley
Only ipod kit is the KCA 420i which isnt going to work with the iphone, either get just an aux in, get a handsfree kit that allows music connection or upgrade your stereo
Sep 29, 2008
835
Bradford
Cheers mt audio, didn't mention in my first post but I have the kca 420i already but TBH I think it's pants, take forever searching for albums etc,
I was wondering about my other options, is there just a plug an play lead which will work?
All works like it should do except I needed to buy a passport to get my phone to charge.
Will the kce422i work?
Mar 3, 2009
823
Hinckley
Not compatible buddy hence me giving you the options.TBH im suprised the iphone even works with it as it doesnt with the 422i
DubSteve68
125
Up North
I decided to go down the upgrade path, and went for this...
I previously had an older generation of Kenwood with an IP500 interface which worked well, but as with many adapters which present themselves as a changer to the head unit, it made use of the analogue line-out signals present on the iPod/iPhone dock connector. This is all fine but it means you couldn't use an Apple dock if you fancied going for a really tidy install without excess wires trailing around and an iPod randomly stashed. The Apple dock splits the line-out signal to a 3.5mm socket, away from the data connections, and is not passed through to the rear dock connector.
My new Kenwood connects via USB and doesn't rely on the iPod/iPhone analogue audio connection at all, and I can finally use a dock for the iPod which looks very tidy. Another bonus of the USB connection is you could use any old USB memory stick and the head unit will play whatever's on it. Which is nice. And on top of that it will charge any iPod that has a USB connection (early FireWire based iPods aren't supported unfortunately) up to and including the latest Touches and iPhones. No Scosche Passport needed...
Final icing on the cake for this particular head unit is that the backlight illumination colour can be fine tuned to your choice - 10 steps for each colour (red/green/blue) mean you can make the head unit look more or less OEM by matching the backlight shade of red to the rest of red interior illumination. Which is even nicer.
Everyone's got their own favourite brands but this is a cracking unit, not too dear at £130 delivered.
DubSteve
