R3k1355
1,899
289
Yorkshire
2003 PD130 (asz)
I need to replace an intercooler hose, it comes from the intercooler to near the alternator.
The metal tangs on the end nearest the intercooler are mullered and it's popping off under boost.
I've found this pipe from Forge, is it the correct pipe or is it another piece??
Fluorosilicone Turbo Hose for SEAT Ibiza 130 Diesel and Skoda Fabia VRS
Product code: FMTHI130D
If it's not the right hose what are my options??
Can I make one up using off-the shelf hose and end bits off eBay?
mines done the exact same boost pipe a few weeks back and I just sourced one through VAG ...mines was only £35 inc VAT
Wow really, the entire lot for 35 quid??
I just paid the same for a fuel filter, I assumed it'd be well over £200
TPS is where I bought mine from ,just take the old pipe off and use the part number on it ,if its still visible :)
To buy from TPS you need a trade account. However I bought one from Seat not about a year ago for £45. Either that or you can make one up yourself using the bayonet adapter you have listed, I also used one of those when building my front mount intercooler pipe work. By the way that forge pipe is wrong, it's designed to go from the turbo into the existing pipe work.
2003 PD130 (asz)
That is not the right part. As per above get direct from Seat. Is it the pipe itself or the clips?
